in need of some help, getting really frustrated
Old May 16, 2007 | 10:34 AM
libertyforall1776's Avatar
Default RE: in need of some help, getting really frustrated
Your battery is dead, and this probably indicates that your alternator needs replacing as well. Have the alternator tested along with the battery... Nothing to do with the computer.
Old May 16, 2007 | 03:51 PM
FallenAngel192's Avatar
alrighty, sorry to be so persistant, just scared the daylights outta me on a busy road. thanks for putting up with me lol. ill post results when i get home from napa in the next few days.
Old May 16, 2007 | 09:22 PM
95camaro's Avatar
Ok its not your alternator from the sounds of it. You said that you try to start your car and it will just die in the process of it starting. But after you disconnect the battery terminal for 5+ minutes and try to start it again its fine. If it was your alternator then when your car died it wouldnt rejuice the battery to start it after that hence your car wont start cuz the battery is dead. So to me it sounds like a computer issue. Unless your recharging your battery after you disconnect it. But you didnt supply that info.
Old May 16, 2007 | 09:26 PM
no i just pop the hood and disconnect then reconnect. im having the alternator tested, battery, and whatever else i can find to test this saturday before work.
Old May 24, 2007 | 02:08 PM
well it seems to be working now, i switched to the other key and replaced the connection between the battery and terminal and she started up everytime.So i guess i overlooked the smaller parts for the big parts, my mistake. So thank you for all the help guys and dealing with my frustration.
maxlily12
Jul 31, 2015 06:40 AM
pbk1994z28
Dec 23, 2011 10:30 AM
Quinid
Jun 30, 2010 07:48 PM
wrnchbndr
LS Series Tech
Jun 28, 2009 08:44 AM
AV95Z
Jun 5, 2007 06:25 PM
