My 95 Camaro 3.4 Build Thread!
#101
Tranny is in and I also put a new throwoutbearing in too before putting the tranny in!
Driveshaft is painted and new U-joints are in!
Painted the rotors silver so the rust won't hit them.
There she sits with the interior in just need to put the shifter on and centre console:
Left to do Monday:
- Front brakes and rotors
- Put coolant back in the engine
- Install driveshaft
- Fill tranny with fluid
- Put new tires on
- Front e-brake cable
Left to do Monday:
- Put new tires on
#105
you might want to check your back wheel wells for rust to. i had little blisters in the undercoating when i took a screw driver to them rust came out and had a few little holes. i patched them and painted them with por15 before applying undercoating.
i was under my car and did see any rust on my floor pans but im gona pull my carpets up when i get it back from being repainted and check them out.
#107
Well, the tranny is back in the car along with the 1-piece driveshaft. The new e-brake cable is on too.
I got the car running! She's running a little rough, but I'm guessing that I need to run her for a bit and let the computer re-adjust itself. I'll also check the plugs to see if they are fouled too. Tomorrow is the drive test. I'll post some pics too.
#108
I drove the Camaro home today! The fuel problem was a vacuum leak that I fixed.
It's still hard to get in gear. Almost like the slave isn't pushing the rod in far enough to change gears. I'll get that worked out this week. I am getting it inspected on Tuesday. Wish me luck!
