Mating Engine back onto Transmission
Old Aug 16, 2009 | 03:01 PM
Riceinator's Avatar
Default Mating Engine back onto Transmission
Hi guys,
I am in the middle of putting my friends 3.4l engine back into his car. We are having some problems getting the engine to slide all the way back onto the input shaft. I know not to force it onto the trans and that it may take some wiggling to get it to match up just right, but we just can't seem to get it to slide all the way on. Are there any tricks that you guys have to share, or any tips to make this any easier?
It's a 5 speed btw.
Thanks.
Old Aug 16, 2009 | 03:09 PM
02StanGT's Avatar
was the clutch taken off at any point?
Old Aug 16, 2009 | 06:31 PM
Riceinator's Avatar
yes, the clutch was taken off. We used an alignment tool and believe it is installed correctly
Old Aug 16, 2009 | 08:19 PM
02StanGT's Avatar
a little wiggling should do it. if not, hand turn the engine just a wee bit, just to see if it helps the splines line up better. a little umph may be required to work.
Old Aug 16, 2009 | 08:50 PM
Riceinator's Avatar
Yea, we have tried turning the engine over a bit already, to no avail. It is on most of the way, just can't seem to get it slide on the last couple of inches. I guess we will try some more wiggling, just not when it is so damn humid out.
Thanks for the quick replies and help.
62rampsidekid
82-92 V6 Tech
Jun 23, 2010 11:22 AM
constantproject
Mar 15, 2010 06:22 PM
Mustangfighter96Z28
Jun 2, 2008 12:07 PM
Nitemare3o5
May 6, 2008 07:55 PM
streetsk8er447
Aug 3, 2006 07:16 PM
