what would make my engine kick back or catch when trying to start it?
Old Jun 1, 2008 | 03:37 PM
Mustangfighter96Z28's Avatar
Default what would make my engine kick back or catch when trying to start it?
when cranking over the engine it will almost start then kickback on its self and i hear a scraping noise but i can't figure out where its coming from. has anyone had this problem before?
Old Jun 1, 2008 | 04:37 PM
74454bb's Avatar
May 2007 ROTM
Default RE: what would make my engine kick back or catch when trying to start it?
I little more detail......get a video clip, check your oil.
Old Jun 1, 2008 | 04:50 PM
ill try to get a clip up, and heres a little more detail. when it cranks, it cranks for longer than it should and i have to hit the gas to get it to even try to start. when i hit the gas it will jump almost like its going to start but then the engine kicks back almost like its out of time but i just replaced the opti yesterday. the only thing that makes sense to me is that there might be a bering going out and stops the belt from truning causing the kick back, does that make sense to you?
Old Jun 1, 2008 | 04:55 PM
also this started happening after it died while i was driving. i was doing about 110 and it suddenly died when i went to down shift and speed up a little bit. but it did some ofthose same things i was talking about in the first post before today so i don't know ifitsa new symptom or not.
Old Jun 2, 2008 | 12:07 PM
LT1RUNNER's Avatar
First of all you should get a diagnostic done to the cars computer. If you have a check engine light on then you may have a faulty sensor. I had a $11 dollar sensor freak my car out to very hard starts, hesitation badly and shut off out when sitting. It only takes one to throw off the cars entire pcm.
reloadx510
Mar 24, 2010 02:56 PM
edog2
Oct 24, 2009 07:00 PM
giants4life07
Nov 13, 2007 12:38 AM
