LSD Carrier, what else is Needed for conversion w/ASR?
Old 11-05-2010, 02:49 PM
libertyforall1776's Avatar
Just look at your cods on the driver door side -- what is your GU code? i.e. GU5, GU6, etc.?
Originally Posted by CamaroDreamer
Yea, idk the current gearing right now. I'll look it up later. It might be 3.42, but im not for sure. But if my gears are 3.42, all i need is the differential?
  #22
Old 11-05-2010, 02:50 PM
I recently had all the bearings replaced in my diff due to whirring noises last year, so I assume they should be good still?
Originally Posted by Gorn
You need the install kit. You have to reset the gears to the new differential. You should go ahead and replace all the bearing while you are at it.
  #23
Old 11-05-2010, 11:42 PM
CamaroDreamer's Avatar
Ok i will take a look at my codes. And thanks, i'll look at an install kit.
  #24
Old 11-07-2010, 01:48 PM
yea its a gu5
  #25
Old 11-07-2010, 01:50 PM
So 3.23 apparently
  #26
Old 11-07-2010, 01:54 PM
So ive got my LSD, now does it have the gears already in it? If so, how do i find out what gearing it has in it?
  #27
Old 11-07-2010, 02:24 PM
where are the pictures? lol turn an axle hub/rotor 1 revolution and count the times the yoke turns, aprox 3 1/4 turn would be 323 aprox 3 1/2 turn would be 342. could do it the other way and see how many revolutions it takes on the yoke to get the rotor to turn once revolution. either way is good.
Chaotic94
11-03-2012 11:31 AM
Chevy101
09-08-2011 05:25 PM
Camaro's kick A$$
12-24-2009 07:35 PM
myohann
03-13-2009 12:54 PM
shnormo
10-23-2006 08:48 PM
Quick Reply: LSD Carrier, what else is Needed for conversion w/ASR?
