ls2 swap to a v6
Old Jun 16, 2010 | 12:54 PM
njredneck's Avatar
Default ls2 swap to a v6
ok i am quite the newb, but mechanicaly inclined i want to build a ls2 and get it in to my v6 camaro. what i am wondering rite now if i swap the k member out of the v6 and get after market k member for the ls1 camaro, will the motor mount up the same as the ls1 with an ls2 in it or am i going to custom make mounts? and oil pan is there a certain style oil pan that i should look into getting
Old Jun 16, 2010 | 12:58 PM
z28rob18's Avatar
probably just the stock oil pan. ask whoever you order the kmember from. i think they may be the same mounts
Old Jun 16, 2010 | 01:01 PM
njredneck's Avatar
ok thats what i was thinkin thanks i no the made the ls engines pretty interchangeable
Old Jun 16, 2010 | 01:18 PM
z28rob18's Avatar
where you from in nj?
Old Jun 16, 2010 | 05:36 PM
Do you know what your getting into? How the motors are not in any way shape or form interchangeable. Your going to need jsut about every engine related part from a LS1 donor car. There is a sticky on the forum that list a lot of info about a V6 to V8 swap.
Old Jun 18, 2010 | 09:58 AM
njredneck's Avatar
yes sir i knew what i was getting into i did not mean the 3800 and ls 1 i ment ls1 and ls2 are interchangeable but i dont have to worry about this as much as i love my camaro it has to go but found a nice fox body mustang at a great price so shell has to go if any one is interested ill sell 800 bucks or best offer or its going to be another camaro in a scrap yard for shell body is a lil beat up needs some body work def paint rear quater has dents only on driver side 3800 series 2 engine is just gunna roll where ever the shell rolls to email me if interested bootscraper619@aol.com
Old Jun 18, 2010 | 11:16 PM
traumadog's Avatar
Be careful - LS1 and LS2 are NOT directly interchangeable, though many parts are common. LS2's are drive-by-wire, and most use a 54x reluctor wheel for engine timing. (Some early '05 GTO's used a LS1-style 24x though) In addition, the knock sensor and cam sensor are in different locations, too - so you can't use a stock LS1 harness without modifying it.
Oh, and it seems a little odd that a day after you posted about the swap, you're ditching the car altogether for a Fox body...
Old Jun 18, 2010 | 11:18 PM
Chaotic94's Avatar
September 2011 ROTM
Where are you located?!
3800_seriesII
Aug 14, 2012 07:24 AM
9434V6
Sep 8, 2011 11:51 AM
xXChipXx
Aug 1, 2010 10:39 PM
miclo88
Oct 15, 2009 07:38 PM
85z285.0
Jun 2, 2007 03:19 PM
