Intake manifold
Old 06-25-2012, 01:26 AM
fbodyrs96's Avatar
you have to change both the upper and lower no way around it make sure you get the metal gaskets, its GM's redesign for the plastic ones leaking all the time. the egr port on the UIM does not have a gasket.
lower felpro MS98014T
Amazon.com: Felpro MS 98014 T Intake Manifold Gasket: Automotive Amazon.com: Felpro MS 98014 T Intake Manifold Gasket: Automotive
upper felpro or what ever brand you want to use, same with valve covers.
heres the heater elbow there talking about Dorman/Heater Hose Fitting (47065) | 2001 Chevrolet Camaro 6 Cylinders K 3.8L SFI OHV | AutoZone.com you only need the long one but it comes with both
its not hard just takes time.
there are to hidden bolts as well
good luck and make sure your torque everything to spec and in sequence, or it will leak again. Haynes has all the info you need.
Old 06-25-2012, 02:51 PM
AMP3D's Avatar
Thanks for those pictures fbody. I didn't think it was hard just time consuming. Once again thanks for the help
princesid84
05-04-2013 01:56 AM
albo1989
07-16-2010 10:54 AM
jc1047
12-30-2009 08:52 AM
Skippysnax
12-27-2008 02:38 AM
jimidude87
03-26-2007 02:08 PM
Quick Reply: Intake manifold
