Which intake Manifold for LS1 ?
Old May 2, 2013 | 10:41 AM
princesid84's Avatar
Default Which intake Manifold for LS1 ?
Ok, I need pro advice please.
Friend of mine wants to install a 'Intake Manifold' in LS1 compatible with a carburetor. My questions are;
a) which Intake Manifold will be compatible with a carburetor in LS1,
b) which ignition system would be required for this setup ? Delco or MSD or any other ?
c) what is the best place to order the intake manifold from ?
Many thanks in advance. Awaiting a reply anxiously.
Sid
Old May 2, 2013 | 02:44 PM
Old May 2, 2013 | 02:57 PM
Thanks for the link.
Would this be compatible with 'carburetor' ?
The guy wants to fix a carburetor and is looking for a compatible intake manifold.
Cheers man.
Last edited by princesid84; May 2, 2013 at 03:00 PM. Reason: (I see that the Edelbrock comes with an ignition already)
Old May 2, 2013 | 03:09 PM
Yes, if you read the description, that setup is for turning the LS1 into a carbureted engine.
Old May 3, 2013 | 03:38 AM
Cheers man, thanks once again for your help. You have always been very helpful.
Old May 3, 2013 | 10:32 AM
I cant actually make out of the picture , if the ignition system has cables to be connected to the spark plugs ?
Old May 4, 2013 | 01:56 AM
Would this coil be compatible ?
http://www.summitracing.com/parts/msd-82858
Thanks.
AMP3D
Mar 22, 2012 11:41 AM
albo1989
Jul 16, 2010 10:54 AM
jc1047
Dec 30, 2009 08:52 AM
Skippysnax
Dec 27, 2008 02:38 AM
jimidude87
Mar 26, 2007 02:08 PM
