idle Air Control valve?!
Old Aug 4, 2009 | 05:48 PM
jjcrago05's Avatar
Default idle Air Control valve?!
Where is it?!?!
Old Aug 4, 2009 | 06:23 PM
Page 56 Item 549 of the parts manual shows you where/what you are looking for. In this pic it is behind the throttle body on the left side.
Just incase you do not allready have it, which everyone should
https://camaroforums.com/forum/93-02-general-41/93-02-camaro-parts-manual-pdf-128-mb-25609/
Old Aug 4, 2009 | 07:03 PM
jjcrago05's Avatar
thank you for that manual
just having a problem, according to the manual it shows the IAC valve to be
just behind the throttle body one the passenger side of the car
but in the picture you can clearly see its not there....is my motor different than
what i think it is?
and could this be the IAC valve?
Old Aug 4, 2009 | 08:30 PM
Thats the map sensor on a air deverter.
Old Aug 4, 2009 | 08:39 PM
i think stan was saying he didnt think the 99s have a iac but the tps did it electronically.
Old Aug 5, 2009 | 02:43 PM
jjcrago05's Avatar
so do you think i need to replace the TPS?
Old Aug 5, 2009 | 02:46 PM
02StanGT's Avatar
If you would have had only one thread on this, you wouldn't need to jump between them to figure out what to try. I posted in the other thread in the main 4th gen section.
Old Aug 5, 2009 | 04:57 PM
jjcrago05's Avatar
yeah i put in under both to maybe target a few more ppl with information
just thought there might be some ppl who looked in the v6 tech thread
and not the 4th gen thread wasnt sure, but should i replace the TPS
sensor or not?
87 camaro z28
Jan 3, 2021 02:01 PM
BLkwdw
Feb 13, 2012 04:28 PM
fortdub99ss
Nov 1, 2010 04:55 PM
jjcrago05
Aug 10, 2009 05:44 PM
94jivvity
Apr 18, 2008 07:29 AM
