Idler Air Control valve?!?
Old Aug 4, 2009 | 05:10 PM
jjcrago05's Avatar
Default Idler Air Control valve?!?
can someone please point out where the IAC valve is
Old Aug 5, 2009 | 11:33 AM
jjcrago05's Avatar
is there not one on this car?! Im stumped...
Old Aug 5, 2009 | 11:37 AM
GMDCAMARO's Avatar
Do you have a Haynes or Chilton Manual by chance?
Old Aug 5, 2009 | 02:32 PM
02StanGT's Avatar
As I discussed in your "oil pressure" thread, your throttle body is all electronic. Meaning your gas pedal has a sensor that tells the throttle body how far to open. I believe you don't have an IAC, and the throttle body controls the idle. The old style throttle body is physically tied to the gas pedal with a cable. Which means once you let off the gas, the throttle goes closed and cuts the air off. In which case you would need a IAC to adjust and maintain idle speeds. Since yours is all electronic, I suspect the PCM tells the throttle body where to be when you aren't pressing the gas pedal. Below is a link to help explain what I am talking about.
Click Me.
Old Aug 10, 2009 | 05:44 PM
TreeWizard's Avatar
02stanGT is correct, my car would die if i let off the gas from high rpms. so i tried to find the iac, but found out there isnt one... all controled by the electronic throttle, took off the throttle body, cleaned it out, works like a champ. hope that helps
87 camaro z28
Jan 3, 2021 02:01 PM
hooknladder
Apr 25, 2011 09:40 PM
fortdub99ss
Nov 1, 2010 04:55 PM
jjcrago05
Aug 5, 2009 04:57 PM
94jivvity
Apr 18, 2008 07:29 AM
