iat sensor
Old Aug 13, 2009 | 04:35 PM
3800camaro's Avatar
Default iat sensor
i was wondering how important it is to have the intake air temperature sensor connected. would i be able to run my car with out it and not have the engine light come on? the car is a 1996 3.8l.
Old Aug 13, 2009 | 04:56 PM
It's a needed sensor, which is why it's there.
IAT=Intake Air Temperature. It senses the resistance of the incoming air, and the resistance decreases as the incoming air temp increases. The IAT sends a signal to the PCM which adjusts the fuel/mix accordingly. Carbureted cars have a choke to adjust the air/fuel richness in relation to engine temp. Injection engines have an IAT, among other sensors. Without it, your fuel mix will be messed up.
Why did you want to remove it anyway?
Old Aug 13, 2009 | 08:00 PM
3800camaro's Avatar
sadly i thought thats what it did and i needed it. i was hoping i would be able to put a cone filter straight to my throttle body but i guess i'll have to go with a cold air kit instead.
Old Aug 13, 2009 | 08:21 PM
02StanGT's Avatar
cold air kit is better than the hot air kit you had in mind
Old Aug 16, 2009 | 02:08 PM
3800camaro's Avatar
Who makes the best cold air kit for the V6 engines?
Old Aug 16, 2009 | 06:11 PM
GMDCAMARO's Avatar
Ebay is probably your best budget CAI.
Old Oct 31, 2010 | 02:18 PM
sebastianwebber's Avatar
It's a very imperative sensor for your car, ebay does sell these things but comes with a very hefty price tag explore other vendors.
________
Old Oct 31, 2010 | 02:24 PM
1augapfel's Avatar
From what I remember the IAT sensor isn't exactly critical during normal operating conditions.
The IAT's main function is to act as a backup temp sensor in case the coolant temp sensor croaks. Then the IAT sensor is *the* sensor for determining open loop fuel mixture.
Still, you don't want to disconnect it and doing so *will* cause the Check Engine lamp to turn on.
fuhhuayt
May 5, 2011 01:04 PM
imcdowel
Jul 26, 2010 11:59 AM
EagleRex
Jul 20, 2010 03:36 PM
Dznuts
Sep 27, 2009 06:48 PM
98sleeper
Nov 1, 2007 01:37 PM
