I don't have a Sway Bar?
Old Oct 11, 2010 | 09:44 PM
  #21
libertyforall1776's Avatar
Hopefully the end-link mount bracket is still there on your car -- did you check? The photo doesn't show the right angle to see it...
Old Oct 11, 2010 | 10:52 PM
  #22
traumadog's Avatar
I was about to say that the end-link is gone. I found out the same with mine.
And FWIW - I'd think about replacing both end links at the same time - the other (rusted) existing link probably won't last long when the stronger newer link goes into place...
Old Oct 11, 2010 | 10:56 PM
  #23
traumadog's Avatar
My bet is that the bolt running through the end-link assembly rusted out, rather than the mount snapping off the body as the end of the swaybar has nothing through it...
Old Oct 12, 2010 | 12:39 PM
  #24
Massey's Avatar
So we find that you DO have a rear sway bar you just dont have end links. Pretty common really I have found a few 4th gens I have looked at have the bar but no links. Just get a set of links and reinstall them and you should be good to go. Moog has a set with poly bushings the bolt is nickle and cadnium plated to prevent rusting.
Massey
Old Nov 9, 2010 | 11:21 AM
  #25
^ I don't know if I would use poly -- it's not ideal in parts that have to move because it's sticky and can bind and compromise movement of a part. Granted there's not a ton of movement in end-links. I think it's an even worse idea on the sway body mounts because of this.
FosterW
May 11, 2011 11:10 AM
thetal1
Mar 26, 2010 08:21 PM
New2Camaro
Jan 30, 2010 06:36 PM
ThirdGenCrazy
Nov 21, 2009 12:27 PM
1979RS
Nov 14, 2008 11:35 AM
