95 3.4 sway bar kits
Old Oct 19, 2009 | 02:56 PM
thetal1's Avatar
Default 95 3.4 sway bar kits
which one would be better
http://www.summitracing.com/compare.aspx
is there a big difference between the hollow and solid construction
Old Oct 19, 2009 | 03:28 PM
the hollow ones should work fine for a v6. u would be better served by getting some good quality struts and shocks. u can get ones that lower the front by about 3/4 in or can be set at stock hight. can get adjustable ones that let u pick the ride. i have koni double adjustable struts on mine and love em. almost stopped the roll on sharp turns. u can talk to sam at strano performance parts. he will set u up with what ride u want.
Old Oct 19, 2009 | 03:29 PM
oh and the link to summit doesnt show parts.
Old Oct 19, 2009 | 05:16 PM
thetal1's Avatar
oh ok here we go
1 http://www.summitracing.com/parts/HS...RO&prefilter=1
2 http://www.summitracing.com/parts/EI...0/?image=large
also i have new shocks and struts on my car. after i replaced them a month later they softened back up to the old worn out ones. they have been on for almost 5000 miles and i would prefer to keep my car stock height just because i hate having the airdam hit the median thing in the front of a parking spot. the other reason i was lookin at sway bars is because the bushings on my car squeak and wd40 will not stop it.
Old Oct 19, 2009 | 10:25 PM
#2 is for heavier cars like a convertable 6 so i think would be over kill.
Old Oct 19, 2009 | 11:24 PM
thetal1's Avatar
so pretty much just look for not solid ones cuz they are for heavier cars?
Old Oct 19, 2009 | 11:33 PM
u want a matched set so get the front and back as a set. if u get unbalanced bars the car will over or understeer big time. i just read the applications on both. one is for three models of v6 and one v8 and the other is for v6 convertables and v8s. i think your thoughs on it are for the most part correct although strano does have hollow ones that are for heavier z s.
Old Oct 19, 2009 | 11:36 PM
thetal1's Avatar
any personal recommendations on brands?
Old Oct 20, 2009 | 12:14 AM
nope. looked into it but decided to go with the struts.
Old Oct 20, 2009 | 12:28 AM
thetal1's Avatar
ok thanks though
