I DID THE SCAN!
Old Nov 8, 2007 | 03:49 PM
maroman209's Avatar
Default I DID THE SCAN!
ok so i went into auto zone, got the scanner and did the darn thing.
it read it in like less than a minute and 2 different things came up
1. random/multiple cylinder misfire detected.
2. manfacurer cotrol auxiliary emission controls.
thats what came up. any idea to what is causing the problem. is the second one a o2 censor?
any help would be apreciated, if i take it into a shop here and tell them what it read, they will want to do a scan themselves and charge me like 80 bucks.
Old Nov 8, 2007 | 06:43 PM
maroman209's Avatar
Default RE: I DID THE SCAN!
nobody knows what the prob can be.. or how to fix it?
Old Nov 8, 2007 | 07:23 PM
ninetysixyenko's Avatar
ORIGINAL: maroman209
that came up when i had a hole in my gas tank, cuz there was no pressure, the holes were in the top of the tank tho
no idea bout other one. sorry.
Old Nov 8, 2007 | 08:08 PM
Gutling's Avatar
misfire can be so many things without looking at it, plugs, wires, coilpacks, injectors are all real easy places to start
Old Nov 8, 2007 | 10:12 PM
Random misfire is usually due to ignition problems or lean fuel mixture.
As for the second problem, this is a propritary code and the scanner used by AutoZone doesn't know how to interperter the code. You need to get the code number and then we can look it up in a chart.
Old Nov 9, 2007 | 11:37 AM
maroman209's Avatar
i will check all the wires and spark plugs.. i kno i can test each individual spark plug by pulling it out and checking for the spark.. how can i test the coils? each one runs me abou 45 bucks. i dont just wanna buy them and have that not be the problem.
Old Nov 9, 2007 | 01:36 PM
The coils should be good, otherwise you would get individual cylider misfires. Most likely the ignition module under the coils, or a failing crank position sensor. In any case, AutoZone can test the coils and ignition module.
Old Nov 9, 2007 | 01:59 PM
Big_Bird_1985's Avatar
I think it could be the 02 sensor in your catalytic converter. If the cat has failed or is clogged it will cause all kinds of fuel and ignition problems. Similiar things happpened to me and it ended up being a recall on the passenger side catalytic converter. I got it replaced by the dealership for free. Maybe this will help you.
Old Nov 9, 2007 | 02:47 PM
libertyforall1776's Avatar
Is there a way to find recalls online per model year?
2kMaro
Jan 3, 2012 12:16 AM
jamesfs912
Oct 23, 2009 06:22 AM
draggo144
82-92 V8 Tech
Mar 27, 2009 04:33 PM
Brians 88 IROC
82-92 V8 Tech
Aug 31, 2008 08:58 AM
SilverBullet5
May 12, 2008 01:01 AM
