grand prix supercharger
Old Dec 24, 2006 | 11:56 PM
jhop16's Avatar
Default grand prix supercharger
would the 3800 grand prix superchargers fit on the camaro 3800?... easily...?? grand prix are being front wheel driver adn the engine sits sideways i figured i'd run into a buttload of problems if i tried to put one on my 99 camaro
Old Dec 25, 2006 | 12:19 AM
Default RE: grand prix supercharger
You are correct, and probably won't fit uder the cowling.
Old Dec 27, 2006 | 04:26 AM
AlfredB18's Avatar
Easy job? No chance, though I have read that someone at FTv6.com is trying the deed, but it's not easy by any means.
Old Dec 30, 2006 | 04:51 PM
camarokyle's Avatar
i been thinking about it as well... if you look at the motors they are similar. yet as you know one is mounted sideways for front wheel drive. but the should not make any difference in how its mounted. the other thing is the throttle body is set back more. the only thing is you need to up your compression and get your ecm flashed. i personaly think that it shouldnt be a problem... what do i know i havent done it and im a new member , but all i can say is look into it...
Old Dec 30, 2006 | 05:56 PM
You have to look how far back under the windshield the engine sits, and then add a supercharger on top of the engine. The sidemounted engines use top mounted Eatonsuperchargers, not the front mounted centrifugal type.
Old Jan 2, 2007 | 06:13 PM
camarokyle's Avatar
that shouldnt matter the intake plenum comes off and the charger takes its place...
Old Jan 2, 2007 | 07:52 PM
Give it a try & let us know how it works out.
Old Jan 3, 2007 | 04:12 PM
bumpnbrd2005's Avatar
Here are the dimensions on a Grand Prix 3.8L Supercharger
19 inches long x 10” wide and 4.5” high
So if you want to take off yourintake plenum, and see if you can fit 4.5 inches between the block and the windshield.
Old Jan 5, 2007 | 12:45 AM
camarokyle's Avatar
im pretty sure you have like 6" or more there ill double check tomarrow.
evilkal
VS
10
May 26, 2008 04:58 PM
buckfever
VS
22
May 12, 2008 11:11 PM
buckfever
VS
23
Apr 23, 2008 10:21 PM
buckfever
VS
Apr 6, 2008 10:06 PM
