fuel filter
Old Jul 2, 2007 | 02:08 PM
maguilar496's Avatar
Default fuel filter
does anyone know how hard it is to change the fuel filter on a v6 camaro and where it is?
i want to change mine but i don't know if i could do it or not
thanks
Old Jul 2, 2007 | 02:32 PM
Andross's Avatar
Default RE: fuel filter
I dont know where it is but it should be just as easy as any other inline fuel filter out there on any car. Look under the hood or even in the Fuel lines under the car as see if you can see the filter. It will have a hose clamp on either side of it. just loosen them and replace the filter.
Old Jul 2, 2007 | 10:20 PM
JaySan's Avatar
I have a 2000 camaro and its on the driver side close to the rear wheels.
Under the car, um.......... its a small cylinder shape. and its not really hard to change.
Old Jul 5, 2007 | 08:01 AM
greg w's Avatar
Jaysan is right, near the rear wheel on driver side. Has a threaded line on the output side and a goofy plastic clip on the input. Wear safty glasses becouse you gotta wiggle the line free and gas in the eyes sucks.
Old Jul 5, 2007 | 09:06 AM
bluovlh8er's Avatar
what jayson said, under the driver rear quarter..... easy if not all rusted. BUY A NEW ONE BEFORE YOU ATTEMPT. because with the new one in hand ull see what you have to do...
Old Jul 5, 2007 | 10:06 AM
libertyforall1776's Avatar
What brands are good fuel filters? Anyone done any real research? We know Fram sucks for oil filters, how about their fuel filters?
Old Jul 5, 2007 | 10:33 AM
desi's Avatar
I prefer AC Delco replacement parts. I think they are around 12 bucks from Summit.
When changing the filter, start the car and pull the fuse for the fuel pump. That will drain your lines and won't make (that big of) a mess when you take the filter off. Be careful with the plastic clip. There ARE tools to remove these, but you can do it with needle nose pliers / screw driver.
Good Luck.
Old Jul 5, 2007 | 01:15 PM
Get the disconnect tools, only about $10 for a set. You don't want to damage the connector and thenhave to replace it.
jon_uscg2001
Aug 25, 2011 12:23 AM
TrammelZ28
Sep 17, 2007 06:44 PM
johnson3034
May 25, 2007 09:35 PM
jtvyper456
Dec 31, 2006 09:33 PM
94camaroLI
May 16, 2006 09:57 PM
