exhust leak
Old Jun 12, 2007 | 01:33 PM
worknon10s's Avatar
Default exhust leak
98 v6 auto
i hear a little rattle from the front adn the smell is so bad it give you a headache/
ive been driving with the window down
is there a common leak on these cars? im thinking manifild on the motor????
thanks
Old Jun 12, 2007 | 02:23 PM
squisher's Avatar
Default RE: exhust leak
Check at the Y pipe right in front of the cat too. Mine has a bit of a leak right after the cat that I plan on doing something about as soon as I can. The sound is more annoying than anything really.
Anywhere there is a non-welded joint would be suspect (even some welded joints if they are in a location that may get stressed by engine movement).
Old Jun 12, 2007 | 04:36 PM
Go to a muffler shop & get it fixed, before you die of carbon monoxide poisoning.
CountTripula
Sep 29, 2013 09:55 PM
Jelz28
Jul 18, 2012 06:01 PM
camaro34
Oct 23, 2010 03:24 AM
camaroFaST
Nov 25, 2005 05:01 PM
camaroFaST
Nov 21, 2005 10:10 PM
