cold air intake
Old 11-06-2007, 12:35 PM
Blue Dragon's Avatar
Default RE: cold air intake
I can't find one for an 02.
Old 11-06-2007, 01:12 PM
02StanGT's Avatar
You're not looking hard enough then. K&N makes one that fits your car. Several other companies make air box lids to replace the restrictive factory one.
Old 11-06-2007, 01:16 PM
ORIGINAL: 02StanGT
Guess I should rephrase that. Can't find one that doesn't cost an arm and a leg. I did see a couple of lids for around $100, all for the V8s though.
Old 11-06-2007, 01:24 PM
02StanGT's Avatar
I'm sure fitting onemade for a '97 3.8 wouldn't be a problem. I'm not sure if anything would be in the way though. That's something I would checkout beforehand. Also, there are some people on here and other forums, that have made their own custom one for fairly cheap.
Old 11-06-2007, 01:34 PM
ORIGINAL: 02StanGT
Yea I thought about picking up the '97 one and seeing if I could mod it to make it work.
Old 11-06-2007, 02:47 PM
aleksandr's Avatar
You can simply mod the stock one without buying any aftermarket parts and get the same result. All you have to do is remove the baffles in the air lid, then polish the inside until its smooth. That will give you better air flow. I haven't done that to mine yet, but other people on the forums here have.
crimson09
12-15-2018 07:07 AM
luciora
04-11-2013 11:17 AM
JOEYCASHCAMARO
04-14-2011 09:04 PM
EasternStryker
02-25-2010 01:53 PM
Quick Reply: cold air intake
