cold air intake
Old Nov 6, 2007 | 12:35 PM
Blue Dragon's Avatar
Default RE: cold air intake
I can't find one for an 02.
Old Nov 6, 2007 | 01:12 PM
02StanGT's Avatar
You're not looking hard enough then. K&N makes one that fits your car. Several other companies make air box lids to replace the restrictive factory one.
Old Nov 6, 2007 | 01:16 PM
ORIGINAL: 02StanGT
Guess I should rephrase that. Can't find one that doesn't cost an arm and a leg. I did see a couple of lids for around $100, all for the V8s though.
Old Nov 6, 2007 | 01:24 PM
02StanGT's Avatar
I'm sure fitting onemade for a '97 3.8 wouldn't be a problem. I'm not sure if anything would be in the way though. That's something I would checkout beforehand. Also, there are some people on here and other forums, that have made their own custom one for fairly cheap.
Old Nov 6, 2007 | 01:34 PM
ORIGINAL: 02StanGT
Yea I thought about picking up the '97 one and seeing if I could mod it to make it work.
Old Nov 6, 2007 | 02:47 PM
aleksandr's Avatar
You can simply mod the stock one without buying any aftermarket parts and get the same result. All you have to do is remove the baffles in the air lid, then polish the inside until its smooth. That will give you better air flow. I haven't done that to mine yet, but other people on the forums here have.
crimson09
Dec 15, 2018 07:07 AM
luciora
Apr 11, 2013 11:17 AM
JOEYCASHCAMARO
Apr 14, 2011 09:04 PM
EasternStryker
Feb 25, 2010 01:53 PM
