coil output
Old Jan 26, 2010 | 07:40 PM
BasicConcepts's Avatar
Technical User
Default coil output
whats the voltage output on the coils in my 95 3.4L
Old Jan 26, 2010 | 09:38 PM
30,000 to 40,000 Volt depending on how fast the engine is going. The faster it spins the lower the voltage as the coils have less time charge. My question, how do you plan to measure it?
Old Jan 30, 2010 | 07:08 PM
Technical User
i was wondering how much more an aftermarket coil from summit was than stock but the coils on my car are original so im sure its a little less than that
Old Jan 30, 2010 | 08:32 PM
libertyforall1776's Avatar
Ask Summit.
(3.8L) MSD Blaster Two-Tower Coil Packs (PN 8224):
http://www.camarohomepage.com/project/part3.htm
"The MSDs put out up to 40kV which, when they're used in an inductive ignition application like the THRS V6, is only slightly more than the OE coils. Where the Blasters are an advantage is during high-load operation at engine speeds beyond where the stock coils normally operate. Our project's engine is soon to get a rev limit higher than stock and future mods, such as nitrous oxide injection, will put a higher load on the ignition. Better materials, such as higher-quality copper wire, and more robust construction means the MSDs will be more reliable when the combination of higher rpm and higher ignition loads typical of a modified engine are present. These coils, along with MSD Super Conductor plug wires installed previously, give us a performance margin we like."
Old Feb 4, 2010 | 11:39 PM
Technical User
well the coils on summit are like 45 50K volts and theyre like 45 bucks so i think im gunna just try em the price is right
pkasprzyk
Feb 19, 2013 09:32 PM
JakeYeah
Dec 28, 2012 09:39 AM
marten
Dec 8, 2010 11:37 PM
91rs350
Jun 6, 2010 05:20 PM
ScottD
Feb 19, 2007 01:35 AM
