Help! Speedo output leaking!
My th350 is pissing tranny fluid from what seems to be every orafice. Upon closer examination, Ive found that where the speedo cable plugs into the tranny is leaking. It is coming from inside the the unit, around the part that actually spins the cable. (As opposed to where the unit actually plugs into the case) What is this part called, and where can I get one?
