Changing turn signal bulbs
I need to change my two front turn signals. Can anyone tell me how to do this or point in to a site that has the instructions? Every place I bring it to says they can't do it so I figure I might try doing. Thanks.
WOW!!! i changed my corner lights to clears. It's a pain in the ***, but it can be done. Underneath you're car you need to disassemble all the plactic guards underneath. Then reach up and take it. It sounds easy, but there a lot of screws. Just jack the front up alil bit to get room and go for it. It just takes time and patience. I think there are 3 pieces underneath you take off each side, thre are 3 screws i think to take the lense out and change the light. good luck!!
Woahhh... I wouldnt go into removing all the plastic from the bottom... did that once n its a pain... its much easier to remove the headlights... Just take the two nuts off of each headlight, wiggle them around a little bit and they r out... then the turn signals r right below there... very easy to get to for either replacing bulbs or replacing lenses
ahlers
27
10-21-2006 03:32 AM
