Car will not start!
Car will not start!
1999 Camero 3.8 The car will not start will neo even crank turn the key everything comes on but will not turn over! I have bypassed the securty system. Last time it did this i took the starter out and had it tested. It was ok put back in and started right up. I am open to sugestions!!! Thank you!
If you have a side mount battery, definitely fiddle with the plugs a bit and try again. They tend to strip out and cause problems in starting the car all the time. Hence why I got a top mount conversion. If not that, check the ground for your starter. Bad grounds can cause all kinds of problems. Just make sure everything is securely connected and clean. Also, make sure the starter is lined up correctly. Putting lock tite on the bolts when putting it in helps a lot. the starters will shake the bolts out if you dont most times. If none of that is the problem, let me know. Next thing to look at would be the ignition system itself.
