Car in Pieces Must Get Stereo Back Together!
Old Aug 14, 2008 | 01:57 PM
Sunshinee's Avatar
Default Car in Pieces Must Get Stereo Back Together!
Hey everyone , I posted in a different seciton but realized it may belong better here ....Last night I began installing two new front speakers and found it to be difficult ....it didn't help that it got dark out and I only had a flash light. I got the first speaker in, but the wires must have came loose as I placed the speaker back into its slot, so now I have to go back in there, connect the wires and install it again. I didn't want to take the entire door panel so I managed to lift the left side I needed and some how shove a ratchet onto the bolts (it probably took longer than if I wouldhave taken the panel off but of well) I know how annoying those clips can be ....I have a 95 camaro with crank windows...Does anyone know how to get the window crank handle off properly ? (I know how brittle plastic becomes after years so I didn't want to mess with it too much without knowing) I need to finish tonight because I left my car with bits, and bolts everywhere so after work I'll finish. Please, if anyone has done this install before and could walk me through it that'd be great otherwise the main thing I need to know is how to get that crank off so that I can get in there easier. One final thing ...it took me about 20 minutes just to find the right mm bit for the screws in the speakers ....tried 8mm, 6mm, 4mm, etc I think I finally found that a small 1/4 worked....whats everyone elses opinion? Thanks so much any help would be awesome!
Old Aug 14, 2008 | 05:07 PM
MusicMan's Avatar
The Jazz Man
Default RE: Car in Pieces Must Get Stereo Back Together!
There's a little c-clip in there. They make a tool to get the clip out, but you can use a wash cloth or a sock. Take the cloth, and get it behind the handle, then grab both ends of the cloth, and pull down. While pulling down, turn the crank handle. The clip will pop off, the handle will slide right off, easily. Make sure you get the cloth wedged in there good so it can grab the clip.
steveonly007
Jun 22, 2015 10:11 AM
oldschool72
Apr 30, 2014 05:24 PM
Sunshinee
Nov 2, 2008 01:18 AM
