3.4 Questions???
Old Aug 3, 2008 | 06:01 PM
BabyVet's Avatar
Default 3.4 Questions???
Ok I'm new here![sm=happy046.gif]So I have a Fiero that i just spun a rod bearing in so i'm going to do the 3.4 camaro swap and i want to set it up for nitrous later on when its broke in. I'm goint to run the Trueleo intake and exhaust with ported and polished heads and the 272H cam and i want to make thisa high compression motor. So i have some questions for you guys?
1. What is theHp rating for the 93-95 camaro 3.4?
2. Is there forged pistons for the 3.4? Or Hyperutitics that reach 10.1 to 10.5?
3. What kinda mods do you guys have done to your 3.4?
4. What kinda Hp and Tq are you getting out of your 3.4's?
5. Are you guys running No EGR?
Old Aug 5, 2008 | 10:30 PM
BabyVet's Avatar
Default RE: 3.4 Questions???
OK so anybody out there?
Come on your suppose to be camaro guys. helping peopleout
Old Aug 6, 2008 | 01:21 AM
Guest
Guest
Posts: n/a
Try the general tech section, very few people do any modding at all to the 3.4L camaros.
Old Aug 6, 2008 | 01:34 AM
Fortee's Avatar
ORIGINAL: BabyVet
I think it's about 120-150?
No one mod's the 3.4s. It's not worth it.
Most 3.4s are stock, cause no one mods em. So refer to question 1.
Old Aug 6, 2008 | 01:38 AM
Guest
Guest
Posts: n/a
Um the 3.4 had either 160 or 180 at the crank, Im not sure, it wasnt 150 it was more than that I know for sure.
Old Aug 6, 2008 | 12:05 PM
camaro_burns_all's Avatar
VIP member
^^ i think he is talking about hp at the wheels not the crank
Old Aug 6, 2008 | 04:30 PM
BabyVet's Avatar
thanks
Old Aug 14, 2008 | 07:13 PM
libertyforall1776's Avatar
1. 160 HP stock
2. don't know
3. SLP CAI, high-flow muffler, cat delete
4. Have not dyno'd it, but I would guess ~175 HP
5. You can safely disconnect it if you don't mind the Check Engine Light that can come on as a result get an OBD I compatible scanner, and you can keep that in check...
ORIGINAL: BabyVet
Ok I'm new here![sm=happy046.gif]So I have a Fiero that i just spun a rod bearing in so i'm going to do the 3.4 camaro swap and i want to set it up for nitrous later on when its broke in. I'm goint to run the Trueleo intake and exhaust with ported and polished heads and the 272H cam and i want to make this a high compression motor. So i have some questions for you guys?
1. What is the Hp rating for the 93-95 camaro 3.4?
Warpig
Apr 20, 2009 09:33 PM
bigjsmashman
Feb 21, 2008 11:05 PM
nj93zkid
Feb 24, 2007 01:20 PM
dubbs95
Oct 21, 2006 01:29 PM
