car does not start.
I have a 96 and i replaced the starter and relay back in november and its been starting great until a week ago when it stopped completly. i thought that it was my ignition as the one key wouldnt work but the other one would. that ended that night. so im thinking its a clutch sensor beacuse when i got to start it with the clutch depressed it does the exact same thing as if im not touching the clutch. i would just like some opinion before i go and replace the sensor and then have it be something else. thanks.
Neutral safety switch could be the culprit.....alldatadiy.com had the best service manuals and wiring diagrams. I would do some reading up and a little diagnosing with a test light before throwing parts at it.
Yes.
Instead of throwing parts at it have you thought of checking with a volt meter? Do you have power going to the clutch switch?
