Bad Oil Leak
Old Aug 10, 2011 | 02:15 PM
  #21
BrianFol's Avatar
LOL yea it is a gusher alright, I would put the car on ramps but I don't have them here right now a friend of mine is using them.
Old Aug 10, 2011 | 02:22 PM
  #22
How about a curb at the street to ramp one side of the car up onto then.
Old Aug 10, 2011 | 03:12 PM
  #23
BrianFol's Avatar
No curb's but I can drive it off the side of the driveway, with each side of the car on the side's of the ditch in my yard. That would work.
Old Aug 10, 2011 | 03:32 PM
  #24
Or, you could dig a hole in the yard and make a grease pit.
Old Aug 10, 2011 | 05:01 PM
  #25
BrianFol's Avatar
OK with having shield off the tranny, and driving the car over the ditch, I was about to get a better look at it, I can see it coming from the plug where the distributor would go this is where it is leaking the most from but it is also leaking from the rear main seal but not as bad.
Old Aug 10, 2011 | 05:20 PM
  #26
Good call 305 camaro on that one! Looks like you just may have saved yourself a lot of r&r time.
Old Aug 10, 2011 | 05:39 PM
  #27
that should be the oil pump drive. should be the same gasket as the old style distributor has. tourqe spec for the drive clamp bolt is 25 ft lbs. when you changed the intake gasket did you do the lower intake?
Old Aug 10, 2011 | 06:15 PM
  #28
slick's camaro's Avatar
correct me if I'm wrong, but I never known the oil pump drive shaft to have a gasket. unless your refering to the rubber o ring that slips in first groove. that's what I changed when I replaced my oil pump. it was just the clamp bolted bolted on top and a lot of built up dirt with the rubber o ring inside on the shaft.
Old Aug 10, 2011 | 07:51 PM
  #29
BrianFol's Avatar
I just have to find the right gasket's or seal's that I need now to get this fixed I have to have this done before monday, cause I need it to drive to school.
Old Aug 10, 2011 | 08:00 PM
  #30
thats alot of oil to be coming from there but then i dont know that much about the 3.4. im sure slick is right and its a couple dollar o ring.
