alleged fuel pump?
Old Sep 11, 2008 | 06:35 PM
supergildo's Avatar
Default alleged fuel pump?
Hey guys, first post here.
I have a buddy with a 97 3.8l camaro. The other day upon starting, the idle was struggling, dropping and raising rpms erratically. My buddy took it in for an oil change and had the filter replaced. Apparently the mechanic told him that he needed a new fuel pump. After research here, Ive seen that often many people suggest the fuel pump is usually the last problem, so I will attempt to diagnose it.
Please forgive me, as I am efficient with suspension maintenance and fabrication, but a bit of an engine newbie. I would like to test the fuel pressure first to deduce if it is actually a fuel problem or an electrical problem. can you fellas aid me in how I would go about this?
thanks in advance!
Old Sep 11, 2008 | 06:48 PM
02StanGT's Avatar
Default RE: alleged fuel pump?
You could get an initial reading for us. There is a schrader valve on the fuel rail on the passenger side. You could hook a gauge there.
94Zman
May 30, 2013 06:54 PM
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
