ABS INOP and BRAKE light stay on, help plz!
Old May 4, 2011 | 09:40 PM
BigAl619's Avatar
Default ABS INOP and BRAKE light stay on, help plz!
So i knw its been asked before but my situation is different i think! My lights(ABS/BRAKE) came on after i jumped started another car! And ever since then it never went away! I took it to autozone and they told me there little computer doesn't want to connect to my car! They said dealer is the only ones that can help me is that true?
Old May 4, 2011 | 10:15 PM
If the Brake light is on, there is either an actual problem with the brakes, or the parking brake switch is not releasing fully. The ABS light indicates that the ABS is not working. May want tho check fuses just in case you blew something during the jump start, including the fuse powering the test port. Not a good idea to jump start another car unless you disconnect the ground cable from the good battery.
Old May 4, 2011 | 10:27 PM
BigAl619's Avatar
Talking
Thanks Pete be sure to check the fuses and my E brake! Never new you had to disconnect the ground to do a jump start good to know thanks!
1995CamaroZ28
Sep 6, 2010 06:51 PM
hpd218
Aug 24, 2010 12:05 PM
3.4CamaroCDOG
Mar 2, 2008 11:55 AM
Skiwee10
Aug 31, 2006 12:54 AM
Skiwee10
82-92 V8 Tech
Mar 9, 2004 02:53 AM
