LT1/LT4 Tech 1993-1997
abs inop and low oil light stay on need help
Old Sep 6, 2010 | 02:01 PM
1995CamaroZ28's Avatar
Default abs inop and low oil light stay on need help
The other day when i started my car the abs inop and low oil light came on and now stay on. I checked the oil its fine i also checked the brake fluid its good. Any idea what it can be. Im going to try and take it to auto zone to see if they can scan it. Thanks
Old Sep 6, 2010 | 02:21 PM
Grandpaswagon's Avatar
For the ABS inop light, check the bulbs in the third brake light. If they are out, it can cause the ABS inop light to come on and the cruise control to not work.
Not sure what would cause the oil light to come on.
Old Sep 6, 2010 | 02:39 PM
The abs and low oil light came on the same time. The third brake light works. I had the car scanned at autozone and nothing came up.
Old Sep 6, 2010 | 06:51 PM
osduck5's Avatar
Check the low oil sensor that screws into the oil pan to make sure the wiring has not been yanked out or the sensor may be bad. ABS, check the wires coming off the front wheel sensor/hub to make sure they are good and clean the wiring connection where they plug into the wiring harness. There is also one sensor on the rear end of the car mounted in the rear axle. Could be a bad wheel sensor if the connections are good.
impala765
May 25, 2012 10:15 PM
BigAl619
May 4, 2011 10:27 PM
hpd218
Aug 24, 2010 12:05 PM
Skiwee10
Aug 31, 2006 12:54 AM
Skiwee10
82-92 V8 Tech
Mar 9, 2004 02:53 AM
