abs inop and air bag lights are on but wont go off
Old 01-28-2011, 02:11 PM
mrfreez's Avatar
That's ok no one is perfect! The front wheel bearings do have speed sensors in them. I double-checked with AllData.
Good to know the rear ones don't! Should make them less expensive to replace! Which aftremarket bearings did you get for the rear? I'm going to change mine and don't want to run into the same issue.
Old 01-30-2011, 10:34 AM
z28?SS?'s Avatar
The Company I went with was National. I didn't see anyone else complain about the part though.... so it might have just been a defective set. If you go with the OE part it is cheap.... the aftermarket ones were about 70 for the set. The aftermarket are designed to run on a different part of the axle shaft than the OE. But if that doesn't matter to you, you might just be better off going with OE.... that way you won't run into the problems you might run into with aftermarket.
Old 01-30-2011, 01:07 PM
Massey's Avatar
National is one of the top bearing manufactures. I would take them or SKF.
Massey
Old 01-31-2011, 09:28 AM
z28?SS?'s Avatar
Ya, I don't doubt they may be a good brand.... Its just that one didn't go in far enough... and on the other the axle shaft didn't fit all the way in.... So we sent them back stock wheel bearings are good enough for me. :P
Josh40601
07-15-2010 12:41 AM
94-z28
06-29-2010 08:30 PM
dm575
11-12-2008 01:10 AM
johnf139
11-06-2006 11:04 PM
V1cinity
10-06-2006 02:46 PM
Quick Reply: abs inop and air bag lights are on but wont go off
