courtesy lights inop on 99 Z28
Old Oct 23, 2006 | 10:42 PM
johnf139's Avatar
Default courtesy lights inop on 99 Z28
Any suggestions? Courtesy lights won't work. Fuse, door switch all check ok w/ multi meter. Door chime works too - but no lights. All bulbs checked ok.
Old Oct 23, 2006 | 10:55 PM
shnormo's Avatar
Default RE: courtesy lights inop on 99 Z28
there might be a broken wire?
Old Oct 23, 2006 | 11:48 PM
johnf139's Avatar
Thanks - guess I'll start - bet that will be fun
Old Oct 23, 2006 | 11:49 PM
Hawk's Avatar
January 2007 ROTM
Default RE: **** lights inop on 99 Z28
There has got to be a wire loose somewheres causing this.
Or it could be in your switch
Old Nov 6, 2006 | 11:04 PM
curtghs67's Avatar
JOhn, I'm having the same problem. And I have some good and bad news. I think it is going to be tied into the Body Control Module. Bad news for you $275, good news = they can wiggle loose and is located behind glovebox. Easy replacement if necessary. I've diagnosed my problem to having good clean wires, fuses, grounds, but the lights won't work as well as the radio and power windows sometimes cut out. The normal noise of "click" when you scroll up on the dimmer switch to activate interior dome light, will not work either I bet. You may hear the noise but prob. won't help. I hear the noise ALL the time driving down the road and I think its either the switch or the BCM. I am tearing apart the switch tom. and checking connections. I'll let you know what I find.
jwoo122
Jan 31, 2011 09:28 AM
DCorey
Sep 16, 2010 04:51 PM
Josh40601
Jul 15, 2010 12:41 AM
dm575
Nov 12, 2008 01:10 AM
V1cinity
Oct 6, 2006 02:46 PM
