96 camaro questions
Old Sep 28, 2010 | 09:50 PM
sexyspeed100's Avatar
Default cat
Originally Posted by mrfreez
Check to see if your cat is plugged.
A cat would cause alot of problems like that?
Old Sep 29, 2010 | 06:01 AM
Keep doing what you are doing and when your done borrow a coolant pressure tester from Autozone.
How many miles on the motor? What do you want out of it? You can just do the head gaskets but if you are ok with stock HP putting in a low miles used motor is the easiest fix.
Old Sep 29, 2010 | 07:16 AM
mrfreez's Avatar
Yes, a plugged cat can be very harmful. It will throw a CEL light with a random midfire code. It can also cause too much pressure in the engine and blow a head gasket over time because of too much pressure. I had the same problem on 2 other cars, and you sound like you have the same symptoms I did.
Old Sep 29, 2010 | 09:18 AM
Default 98k miles
Ok thanks, i will do that. the motor has 98k miles on it, i kinda wanted to get full use out of the motor and tranny b4 i went and changed the motor.
Old Sep 29, 2010 | 09:19 AM
Default testing head gaskets
Is there a way to check to see if the head gaskets are bad other than removing the heads?
Old Sep 29, 2010 | 09:29 AM
i will definiately look into that. thank you
Old Sep 29, 2010 | 10:39 AM
I do not think a plugged Cat will cause a blown headgasket. The High back pressure will not allow the cylinder to completely evacuate, This would mean the cylinder would draw in less cool oxygen. Less Oxygen = Less power = Less cylinder pressure. Once the back pressure reachs 8-10 PSI No Air will get into the cylinder and you are down to compression test numbers (under 200 PSI)
The reverse is possible a blown head gasket can cause a plugged cat because it screws up the nice clean burn the motor should have.
Old Sep 30, 2010 | 06:28 AM
mrfreez's Avatar
Yes, a plugged can cause head gaskets to leak. I went to the dealership and even got a second opinion elsewhere. You could smell antifreeze when I turned off the car after driving it. Once I replaced the cat, everything was fine. Luckily I got it in time before there was damage to the head gaskets. Both the dealership and other mechanic confirmed a head gasket can blow from a plugged cat.
ltrey007
Aug 27, 2013 05:15 PM
lobby350
Apr 23, 2011 10:59 AM
MB2hurley
70-81 V8 Tech
May 24, 2010 11:27 PM
Murray
82-92 V8 Tech
Feb 11, 2008 09:24 PM
1911luver
May 2, 2006 01:45 AM
