96 3.8 5 speed
I can't shift and there's no fluid in my clutch master, just bought the car 5 months ago I noticed shifting into reverse if clutch was all the way pressed I couldn't do it I had to release a Little and it would engage also shifting into second would grind like I didn't press the clutch enough when it was im thinking it's a leaking slave what's yalls thoughts
With that setup you should just replace the whole setup. Master, hose and slave. They tend to fail one right after the other. You should also think about replacing the clutch since you need to remove the trans to replace the slave anyways. The Slave is part of the release bearing and is on the input shaft of the trans.
