t-56 transmission problem! Maybe the clutch
Old Jun 6, 2009 | 10:25 PM
nazariol's Avatar
Default t-56 transmission problem! Maybe the clutch
I have a 99 ls1 camaro and today when i went to turn it on the clutch pedal stays down and it wont come back up ! all my gears are locked and i cant shift to any gear! any body have any ideas someone said that it migth be my clutch ! if so will a zo6 clutch installed new for 900 be too much? let me know please
Old Jun 7, 2009 | 12:50 AM
sounds more like a master and/or slave cylinder. check the clutch fluid level and look to see if theres fluid leaking anywere around it or the driver side of the front part of the transmissionl. when a clutch goes its almost the opposite of what u have.
Old Jun 7, 2009 | 03:32 AM
daragez's Avatar
i agree!...try it!...
Old Jun 8, 2009 | 02:01 PM
95slvrZ28's Avatar
It a problem with the clutch system, not the clutch plates themselves. It sounds like the clutch isn't bled correctly so it's not disengaging the actual disk, thus the reason all your gears are locked. You either had a master/slave cylinder go bad or you're leaking fluid.
Old Jun 10, 2009 | 10:14 PM
nazariol's Avatar
thanks guys it was actually the slave cylinder, i replaced the clutch while the transmission was out have a z06 clutch now
windsorman707
82-92 V8 Tech
Oct 2, 2010 09:10 AM
Chucky
Jul 10, 2009 11:44 AM
CRCustoms
May 23, 2008 05:57 PM
JuggernautX
Apr 2, 2008 06:44 AM
Rise65
Nov 8, 2007 10:58 PM
