CLUTCH PROBLEMS Grrrrrrrrrr!!!!!!
Old Apr 23, 2006 | 10:04 PM
Liljedi's Avatar
Default CLUTCH PROBLEMS Grrrrrrrrrr!!!!!!
I have a 96' Camaro and i can fill up the clutch container and my clutch will be good for about 4-7 days, and then i will refill it and it will do it again for another 4-7 days. i just replaced the slave cylinder and it is still doing it. I am pretty much at a stoppong point and my brain is totally stumped, i think the clutch is still good b/c i had good clutch when i was having to refill the container. If anyone has had this problem or can help I would veru much appreciate it. Thank you.
Old Apr 23, 2006 | 11:19 PM
v8chvyguy's Avatar
Default RE: CLUTCH PROBLEMS Grrrrrrrrrr!!!!!!
did you check the clutch master? it's probly leaking at the firewall
Old Apr 24, 2006 | 12:56 AM
Liljedi's Avatar
the container that i put the fluid in or is it a different one
Old Apr 24, 2006 | 01:42 AM
v8chvyguy's Avatar
That container will be attached to the clutch master
BlueKitsune
Jul 22, 2020 08:55 AM
chewybacca11
Oct 26, 2010 03:36 PM
blazelt1
Mar 12, 2009 06:10 PM
highroller814
82-92 V8 Tech
Apr 20, 2007 10:56 PM
Liljedi
Sep 18, 2006 02:24 AM
