95 auto Tranny problems HELP!!!!
Ok so ive had my car about 2 years now..........and ive recently been doing some heavy daily driving and the tranny runs perfectly fine when the temps are down...........once it starts to heat up the problems begin...........it doesnt downshift or upshift correct. Whut should i do about this......i dont have the money for a tranny overhaul or a new tranny wuts can i do that might help this problem i have taken it to 2 mechanics already i dont have $1500.........should i do a transmission flush??? how much does it cost??? pleas give me ur input on my problem...........i dont want to have to drive that POS saturn that has numerous problems!!! (and thats an understatement)
[IMG]local://upfiles/8461/B1E5415268724069AD6E6B4F010E39B6.jpg[/IMG]
The easiest thing to try is drop the pan and replace the filter and add back in Dexron 6 (not 3! 6 lasts much longer and has much better chemical properties while being fully backward compatible) -- while this won't get all your fluid, this is sometimes a "safer" way to address trans issues -- some claim that doing a power flush can sometimes render a car unusable due to upsetting the fluid balance present... If you do a power flush, also have the filter changed, and clean the pan magnet... If there is no magnet, add one.
I just dropped the pan and changed my filter on my '95 and put back Dexron 6, messy, time consuming, but not really hard.
You could also look into transmission cooling options... But the truth is, if you really have a trans problem, then fluids are not going to solve your physical problems... but you can try the fluid change first, it is certainly cheaper!
On another note, I once had my '95's auto-trans linkage fixed, as the auto-shifter was not working right going from neutral to drive lets say -- the positions were off and totally unreliable, this was not a big deal to fix, and had nothing to do with the trans....
