94 v6 camaro rear end gears
Old Mar 3, 2011 | 11:56 PM
carterbrad94's Avatar
Default 94 v6 camaro rear end gears
ok i have a 94 v6 stick 5 speed an im just wondering what rear end gears r in it
Old Mar 4, 2011 | 12:12 AM
3800camaro's Avatar
It's either 3.23 or 3.43. If you look in your glove box there's a list of codes look at them then go to the forth gen section ( not the v6 specific one) there's a sticky that has what each code is. Hope that helps ya.
Old Mar 4, 2011 | 12:19 AM
3800camaro's Avatar
Ok so I thought I'd look it up for you and here they are:
3.08 is code AU4, 3.23 is AU5 and 3.42 is code AU6.
So there should be list in your car glove box with a list of RPO codes and find one of the ones I listed and that's your gear ratio.
Old Mar 4, 2011 | 10:26 AM
mrfreez's Avatar
As far as I know, most of the 95 manuals had 3.23 gears. That's what's in the back of mine. I'm replacing them for 3.42 posi.
Old Mar 4, 2011 | 03:58 PM
thanks guys
Old Mar 4, 2011 | 04:10 PM
mine is au3 what is that
Old Mar 4, 2011 | 05:01 PM
3800camaro's Avatar
Oops I messed up the codes. It supposed to be GU4 GU5 GU6.
AU3 is power locks on side doors.
Old Mar 4, 2011 | 07:06 PM
gu5 i guess thats ok gears i really want 3.73 gears
Old Mar 4, 2011 | 08:43 PM
3800camaro's Avatar
3.42 is pretty good gearing for all around driving. If you want 3.73s then get the rear diff from a z28. Then you'll gain posi which will help for acceleration with those gears.
Old Mar 5, 2011 | 10:28 AM
mrfreez's Avatar
3.73 gears are the gear ratio from the 2nd and 3rd gen Z28's.
4th gens has 3.42 manual and 3.23 auto. I recommend a higher ratio for manual and lower for auto. Otherwise you'll be at higher rpm on the highway. I find 3.42 on the manual and 3.23 on auto just about a perfect balance for highway and power leaving the line. With posi of course!
Dillon5224
Apr 25, 2010 07:09 PM
Prime1979
Sep 9, 2009 10:12 AM
whammer3024
Feb 1, 2008 08:05 PM
daltons 1980
Nov 9, 2007 12:01 PM
gozzy341
Feb 15, 2007 10:28 PM
