94 V6 3.4L Camaro Problem
Old Sep 17, 2009 | 12:26 PM
94camaro94's Avatar
Default 94 V6 3.4L Camaro Problem
I have a 1994 V6 3.4L Camaro. When I start it runs rough, when I drive it and get somewere and turn it off,it will not start back up for another 6hrs.I was wondering if you guys had any ideas on what it could be.
Thanks
Old Sep 17, 2009 | 02:43 PM
ElementSkater's Avatar
Check your plugs and wires, Also when was the last time you ever performed a full tune-up? There can be other things, sensors fuel pump, ect. Does the engine turn? do you have pressure?
Old Sep 23, 2009 | 08:54 AM
94camaro94's Avatar
Ya I accually have got new spark plus and plug wires. I thought it could be the coil packs so i replaced them also. I hear the fuel pump turn on and I have replaced the fuel relay.
Old Sep 29, 2009 | 09:50 AM
clrklinebacker55's Avatar
i had kinda the same problem mine ran rough due to mis gapped plugs and wouldnt start due to failing starter if you sit there and turn the key on and off on and off over and over again till it starts could be the starter thats what it was with mine
Old Sep 29, 2009 | 01:17 PM
so does it turn over and not start? have u tried a fuel filter? ignition modual? the list goes on. have it scanned for trouble codes and see what comes up. are u getting ses light or security light?
Itsalifestylee
Dec 13, 2010 08:00 PM
hendogg1114
LS Series Tech
Jul 14, 2009 09:24 PM
akajoe87
Feb 17, 2009 02:35 PM
80s don
Dec 3, 2006 10:31 PM
80s don
Dec 2, 2006 12:44 AM
