2000 camaro v6 wont stay runninng after warm
Old Nov 12, 2011 | 04:10 PM
smokeytires's Avatar
Default 2000 camaro v6 wont stay runninng after warm
Hello new to the site need some help with 2000 camaro v6 my son has. He installed front wheel drive engine into his camaro he has change most everything you mentioned in your forum. his problem is it wont idle after warmed up,it dont throw no codes and if you disconnect maf sensor it runs good. he has replaced it twice thinking cheap one was bad.any information would be helpful. thank you S/T
Old Nov 12, 2011 | 09:48 PM
The engine has two operating states, open loop and closed loop. When cold it works in open loop and ignores most sensors, when hot it work in closed loop and uses all sensors. The reason it works with the MAF disconnected is because the disconnect forces it back into open loop. There is nothing wrong with the MAF. Most likely something has been omitted in the swap. Connect a scanner and see if any codes are set, and check freeze frame data.
Old Nov 12, 2011 | 10:28 PM
Thanks for the information. He did it all by himself so its possible that he missed something. I just guessed it would throw a code but what you said may have explained that . Im still learning this computer crap little. I'll have to go look it over and see if I see anything.thank you s/t
mbnntt7
Jul 18, 2011 04:41 AM
camarokid1488
82-92 V6 Tech
Aug 23, 2010 02:22 PM
camarokid1488
82-92 V6 Tech
Aug 7, 2010 11:25 PM
camarokid1488
82-92 V6 Tech
Aug 7, 2010 08:19 PM
Jocam
Dec 30, 2009 05:58 PM
