Z28 rear axle swap in a base 94 camaro
Old Dec 21, 2018 | 11:36 PM
Djnutting's Avatar
Default Z28 rear axle swap in a base 94 camaro
Hi i have a 1994 chevy camaro base i was wanting to do the z28 rear axle swap in mine but wondered what all parts and other things do i need to get to make it a successful swap. I really want the disc brake rear end that they came with is one of the reasons plus im trying to make my camaro hold 600whp. Thx for all the help guys and gals.
Old Dec 22, 2018 | 05:42 AM
if your changing the whole rear differential then thats all you need. also, get the e brake cable and brake lines from the z28 diff
Old Dec 22, 2018 | 10:52 AM
Y2K's Avatar
Y2K
Originally Posted by Djnutting
plus im trying to make my Camaro "hold 600whp." Thx for all the help guys and gals.
If you plan on making that much power you want something a lot stronger than a stock Z28 rear end.
The Z28 rear is a nice upgrade but not built for that kind of power.
The factory 10 bolts in 4th gens often fail behind a stock engine with less than half that much power when pounded on.
Building for that much power isn't going to be cheap and the rear end is no place to scrimp.
You'll need something more like this and take note the price is before many needed options.
M9 Fabricated 9" Ford Housing & Axle Package - Moser Engineering
If you search you might find a drag car roller or part out and save a lot of money, good luck!
94.V6.VROOM
Oct 1, 2009 04:11 AM
davefh
Apr 3, 2007 09:34 PM
84Z28
Jan 30, 2007 01:44 AM
t4nk
Aug 30, 2006 02:10 AM
xaviervp
Dec 10, 2005 02:20 PM
