Rear Disk brake swap / upgrade
Old Dec 6, 2005 | 04:57 PM
xaviervp's Avatar
Default Rear Disk brake swap / upgrade
My has a 1986 Camaro sport Coupe, 305 auto, AC etc all in great shape, very,
I mean very low miles only 82,600 ORIGINAL miles 2 owners and they were
family all it needed was a tranny overhaul, had that done today for 600.
I would like to swap the rear drum brakes for disk brakes what would be a good donor for this swap, what model
and year range.
Also what parts would I need to remove from the donor so I don't miss anything.
Thanks
Xavier
Old Dec 7, 2005 | 08:28 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: Rear Disk brake swap / upgrade
you def. need a new master cylinder to do that swap and im pretty sure a different rear
Old Dec 7, 2005 | 11:18 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
http://www.thirdgen.org/newdesign/te...reardisc.shtml
Everything you need
Old Dec 10, 2005 | 02:20 PM
RatedZ's Avatar
ORIGINAL: xaviervp
and year range.
Thanks
Xavier
You may be able to do a Corvette brake upgrade. I'm not sure if the 1986 rear is different from the 1991 rear on the Camaros, but the 1991 B4C Camaro had the 4 wheel disc brake setup from the Corvette. You might want to look into that.
I'm not sure if you would have to swap the rear. I'm not real knowledgeable when it comes to whether you need to upgrade the rear when upgrading from drums to discs.
If it's not much trouble, look into Stop Tech, Wilwood, Baer, Brembo, and SSBC. They all make nice kits.
craby
Aug 11, 2012 09:13 PM
dmoneey05
Jul 14, 2012 05:58 PM
GSchubes
Apr 10, 2010 08:41 PM
DJAbby
67-69 V8 Tech
Jan 8, 2009 06:55 PM
jweb47
67-69 V8 Tech
Nov 29, 2008 09:21 PM
