94 base rear z28 swap
Old Sep 30, 2009 | 10:06 AM
94.V6.VROOM's Avatar
Default 94 base rear z28 swap
Hello, would i be able to just swap out my rear end on my base camaro and then put a z28 one on with the disk brakes? All it would really be is running the brake lines and ill end up getting new shocks. and just hooking up and bleeding the lines. Or am i missing something? THANKS!
Old Oct 1, 2009 | 01:55 AM
im getting conflicting info on wether the 4th gens are all the same. the lt rear end will fit im just not sure u can fit a 2000 rear end under a 94. some info says 93 to 97 are the same. some infor says they are all the same. 93 to 2002.
Old Oct 1, 2009 | 04:11 AM
maudyZ28's Avatar
i think they should be interchangable, as most of the part you can get are the same, ie the control arms, panhard rod etc all go through from an 82-2002 as the axle is same, on the 4th gen 93+ f-bodies the caseing and mounting points are the same so it bolts in, just be aware the gear ration is different and also the shock and springs are a different rate if you have lt rather than ls1 engine due to weight
Bepps95_3.4
Mar 23, 2012 12:26 AM
brian383
Aug 3, 2010 10:48 PM
the general
May 11, 2010 10:58 AM
shippy8907
Feb 3, 2009 07:03 PM
solei
Dec 5, 2008 08:34 PM
