Trany Question
Old Jul 24, 2005 | 01:05 AM
mikeyanni05's Avatar
Default Trany Question
My 95' 6speed slips out of gear and grinds whenever I put it in reverse, i need to rebuild it and wanted to know what part may be causing this problem. Also, where is a good place to find rebuild kits?
Old Jul 24, 2005 | 12:39 PM
JD1969's Avatar
Default RE: Trany Question
Could be a bent shift fork, which is pretty common on the T56.
Old Jul 25, 2005 | 03:15 AM
Thanks for the reply.
Do you know if the fork can be straightned and if so does the trans. have to be droped to reach the prob.
If it can not be straighned, how much do u think this park will cost?
Old Jul 25, 2005 | 09:04 PM
JD1969's Avatar
The trans will need to come out, it's not really that hard, the fork needs to be replacedand while you are in there you might as well rebuild the whole thing. don't know how much a stock rebuild would be as it can differ from shop to shop.
GMguy94
Jun 19, 2009 11:45 AM
cerbid
Feb 22, 2009 12:28 AM
cerbid
Jan 19, 2009 10:28 AM
javione
LS Series Tech
Sep 20, 2007 01:12 AM
americanpower454
Dec 26, 2006 10:57 AM
