Trans swap
Old Oct 27, 2013 | 07:33 PM
street lethal Z/28's Avatar
Default Trans swap
If I'm not mistaken the 94 z/28 has the 4l60 trans right? I'm just wondering if it would be better to swap to the 350 turbo or 400 turbo. Looking for something good For track use but still decent to cruise on the weekends. Also what kinda costs and how much work would it be to switch?
Old Oct 27, 2013 | 09:40 PM
Chaotic94's Avatar
September 2011 ROTM
Keep the stock tranny. Get a 2800-3200 stall and a shift kit. You'll be plenty happy with that.
Stall converter could cost up to $1000 for an expensive one. Can be had on ls1tech in classifieds for maybe $500? I've heard from many auto drivers that vigilanty is a good brand for a stall. Not sure if I spelled it right tho. I wouldn't cheap out on a stall. Get a quality brand. As for the shift kit, they can be had for under $100 if I recall.
Old Oct 27, 2013 | 09:42 PM
Well when I bought the car I was told it already had a shift kit and stall in it , just not sure how big of a stall. I'm just having a little trouble out of the tranny so I've been considering a swap
Old Oct 27, 2013 | 09:45 PM
Chaotic94's Avatar
September 2011 ROTM
Hard to say. I'd pull the trans and look at the converter. You'll be able to tell if it's factory or not. And for the shift kit, with an aftermarket shift kit, you'll roast 2nd out from under the back of the car with ease. Not so much with a factory tranny. Maybe chirp 2nd at best
Old Oct 27, 2013 | 10:00 PM
Well here's my problem maybe you can help me narrow it down, if I'm going down the road and punch it the car should go into "passing gear" right? My problem is if I punch it the RPM's jump up like its in neutral.
Old Oct 27, 2013 | 10:07 PM
MKCoconuts's Avatar
Which it should do. If it kicks down in third, you're rpms would go up. You're going from .68:1 ratio in fourth, to a 1:1 ratio in third.
Old Oct 27, 2013 | 10:23 PM
But it should still be making forward power right? Mine acts as if it is in neutral no power and redline rpm .
Old Oct 27, 2013 | 11:52 PM
If the trans isn't downshifting and making the car go zooooom, then you're describing a slipping transmission, which means the clutch packs are toast.
Could be previous owner put in a shift kit in the hopes of it fixing the problem.
Old Oct 28, 2013 | 01:56 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Sounds like a toasted trans to me, ive broken 4 so far.. If you dont plan on making big horsepower then just stick with the 4l60e.
3800_seriesII
Aug 14, 2012 07:24 AM
timmyz28
Dec 20, 2010 09:57 AM
91CAMARORS305V8
Dec 6, 2008 12:17 AM
91CAMARORS305V8
Dec 4, 2008 03:07 PM
SC175H
Aug 3, 2006 03:55 PM
