quick trans question
Old 01-15-2012, 02:58 PM
BasicConcepts's Avatar
Technical User
not sure ill have to check
  #32
Old 01-15-2012, 03:11 PM
If the tag is gooped up with grease, don't clean it off with a solvent. You could wash off any printed i.d. info, if it has any.
  #33
Old 01-15-2012, 03:15 PM
Technical User
no i just took the hose and a soft brush to it... anyways theres no serial numbers on that sticker but in the lower rear corner theres a badge with some numbers ill get a pic
  #34
Old 01-15-2012, 07:21 PM
Technical User
so i was in the middle of the install about to take a pic for my how to and i dropped my fone and cracked the lens so no write up
but on a good note this kit is pretty easy to install
  #35
Old 01-15-2012, 09:07 PM
Technical User
what do you guys think of recycling trans fulid??? ive got a trans full of 50 mile old fluid. i was thinking i could get some pantyhose and double them up and filter the fluid through that than run a magnet through it as a double check
  #36
Old 01-15-2012, 09:13 PM
what do you guys think of recycling trans fulid??? ive got a trans full of 50 mile old fluid. i was thinking i could get some pantyhose and double them up and filter the fluid through that than run a magnet through it as a double check i have a REALLY strong magnet the only way to get it off the side of my tool box is to pry the corner up (its square) and use piece of wood under it
Is that the trans that was slipping on you, and probably burning up the clutches? For what you're going to save, it's not worth the chance of still having grit in the fluid once you're done. Not to mention, the cost of replacing your nylons (we're don't ask, don't tell here)! Treat the new tranny to some new fluid.
  #37
Old 01-15-2012, 09:17 PM
Technical User
lol because theres been so many
no its the trans that was working perfectly than went boom and then didnt work
ohh and i got plenty of hose
  #38
Old 01-15-2012, 09:25 PM
lol, I know, you've gone through so many tranny's, I lost track. If you're convinced to go that route, be sure to use the panty hose with the cotton panel. If it's good enough for.....eh never mind!! lmao. But still, I'd go with new fluid.
  #39
Old 01-15-2012, 09:29 PM
Technical User
lol new fluid it is
  #40
Old 01-15-2012, 10:17 PM
mezzyshredder's Avatar
Banned
Let me know how the kit works out. Good luck. Hopeful it does the trick and your off to the races,lol.
Quick Reply: quick trans question
