Limp mode? Need help
Old Nov 20, 2018 | 12:21 AM
peterpar's Avatar
Originally Posted by MrTacticity
I’m not sure what manual he is talking about and what repair tree.
Gorn is trying to point you to this page in the Camaro Reference, Repair and Owners Manual Section where you can download a copy of the GM factory service manual for your car. If you use an Acrobat Reader program to open this file, you can use the bookmarks on the left side of the window to navigate through the different sections to find what you're looking for. To save time, I extracted the pages which pertain to DTC P0756. You didn't say if your car is a 6 or 8 cylinder engine so I included both. I would suggest taking the time to read what conditions will set this code to be able to better understand what your problem may be. Hope this helps.
File Type: pdf
Old Nov 20, 2018 | 05:05 AM
yes reset code and is not back.. I’m not sure what manual he is talking about and what repair tree.
96 factory service manual is a 2 book series, peterpar has given a link to download electronic version. i get lost in it so use paper. getting harder to find and prices are climbing. heres one on ebabe that has an extra 93-96 book https://www.ebay.com/itm/1993-1996-S...4383.l4275.c10
Old Nov 20, 2018 | 10:20 AM
peterpar's Avatar
Originally Posted by craby
I get lost in it so use paper.
Craby, if you open the service manual file with an Acrobat Reader program, you can use the bookmarks options to find the section of information you're looking for just like you would with a paper copy. Once the bookmark window is opened, you can click on the topic you're looking for and it will go the first page of the topic selected. The pdf I've attached a should help explain how to access and use the Bookmark feature. If you haven't downloaded the service manual files in the last year, you may have to download it again to get a copy with the bookmark updates.
File Type: pdf
Heritage
Nov 23, 2017 10:29 AM
hoursetraitor
Mar 27, 2011 05:07 PM
maudyZ28
Nov 26, 2010 02:31 PM
z28pete
Nov 21, 2010 12:46 AM
Renegd98
Sep 27, 2007 04:55 PM
