leaking trans
Old Sep 13, 2011 | 04:41 PM
ronnie32567's Avatar
Default leaking trans
just bought a 1994 camaro V6 auto trans. Trans shifts fine but leaks fluid. The fluid is just pouring down the passengers side looks like its coming from the top of the trans about midway back. Only leaks when in gear, blocked car up and put in drive, big stream of fluid pouring down the side of the trans. Help.
Old Sep 13, 2011 | 05:20 PM
Check the trans fluid cooler lines where they connect to the transmission, they have a habit of leaking.
Old Sep 13, 2011 | 05:45 PM
....Also check your filler tube where it goes into the top of the case, and the tube itself for rust holes.
Old Sep 13, 2011 | 11:04 PM
yea I checked those. The fluid looks like it is coming from the top side of the trans. I don't know if there are any lines on the top. muffler was too hot to try to feel the top, I'll do that tomorrow.
Brian Z.
Dec 15, 2014 08:53 AM
olered
Nov 13, 2011 08:52 PM
libertyforall1776
Sep 13, 2011 12:28 PM
scottlee1
Mar 11, 2008 11:30 AM
BobbyX
70-81 V8 Tech
Nov 15, 2007 01:58 PM
