help with trans pan leaking puddles every where and now my wife's pssd @ the mess
Old Mar 10, 2008 | 08:05 AM
scottlee1's Avatar
Default help with trans pan leaking puddles every where and now my wife's pssd @ the mess
i have a th350 in a 69 camaro that is driving me nuts. i have replace gasket twice and just now pan cork gasket. still leaking between case and gasket. it also seems to be leaking around a few of the bolts. does any one have any sggestions on what i can do to stop these leaks, silicone or something maybe?
ps already cheched front seal and arounf linkage. its leaking at gasket
help please
scott
thx
Old Mar 10, 2008 | 08:23 AM
tommynos's Avatar
July 2007 ROTM
Default RE: help with trans pan leaking puddles every where and now my wife's pssd @ the mess
ORIGINAL: scottlee1
help please
scott
thx
Well first off make sure your not over filling it,which makes it come out the little over flow on the top which will make it look like its leaking around the pan..when the car is running and warm check it properly then,but assuming you have not over filled it,then I would take the pan off again and scuff it with sand paper to make sure its flat with no debree,if all fails just put some silicone around the bolts prior to installing them,thats what I do to my intake bolts and I never have puddles on my intake..
Old Mar 10, 2008 | 11:03 PM
t9ojetpilot's Avatar
[&:] did you peen the bolt holes back down?? often it was a gorilla that tightened the pan bolts and inverted them and if you dont peen them back down you will often have leaks as the bolt holes become the high spots and dont allow equal pressure to the rest of the gasketing surface kurt
Old Mar 11, 2008 | 11:30 AM
LT1RUNNER's Avatar
Fix it quick or there may be no nookie for you in the near future!!! I use a little silicon and I also spread some on the bolts before I install the pan. Good luck with both problems.
Brian Z.
Dec 15, 2014 08:53 AM
ronnie32567
Sep 13, 2011 11:04 PM
rs coastie
Jan 3, 2008 09:50 PM
BobbyX
70-81 V8 Tech
Nov 15, 2007 01:58 PM
