ATF in Manual Trans??
Old Oct 5, 2012 | 09:40 PM
pobasturd's Avatar
Default ATF in Manual Trans??
I just read in my Chilton's that my 5-speed manual takes 3.4 quarts of ATF. Being an old school kind of guy this seems weird to me. We used to use it in the transmissions of some old 2-stroke dirt bikes, but cars usually got gear oil. Is this really the best thing for it, is synthetic ATF OK, and if there is a better alternative, what might that be?
Old Oct 5, 2012 | 09:45 PM
BasicConcepts's Avatar
Technical User
I thought the same thing when I flushed my 3.4l m5, but ya use atf. As for synthetic I doubt it will hurt.
Old Nov 3, 2012 | 04:09 PM
Everett#2390's Avatar
If you think from a gas mileage stand point, ATF is easier to turn than thicker gear lube.
Same reason for 10W30 to 5W20 engine oil weight, lees power given up in pumping oil.
Old Dec 11, 2012 | 11:06 PM
Z28Camaro98's Avatar
if i understand it right, these transmission being constant mesh, need the atf so the blocker rings will work properly. Using tradition gear oil will make them malfuntion.
Old Dec 14, 2012 | 08:01 PM
Not necessarliy, Muncie's, Saginaw's and BW T10's are constant mesh just like T5's and T56's. Same design, just different lube, easier to turn.
Old Dec 14, 2012 | 11:30 PM
oh okay thats the only thing i could think of, for why it needs ATF
olered
Nov 13, 2011 08:52 PM
pimpjuicepd
Jun 13, 2008 12:44 AM
sewerrat
May 3, 2007 12:28 AM
brock417
LS Series Tech
Jun 30, 2006 04:35 PM
81TT
Mar 21, 2006 12:47 PM
